it grinds
I have a 89 305 5-speed, and it grinds everytime i put it in 5th gear. What can possible be the reason? To avoid grind in reverse and 1st gear I ALWAYS put it in 2nd gear then to 1st and 5th gear then to reverse, for some reason those two gears wont grind if i do that, but its tough to do something like that when going from 4th to 5th going 70 mph. Any help would be great.
ORIGINAL: rockin85
to avoid grinding, when in 4th pull it into nuetral and let the clutch out then put it back in and slide it into 5th. in other words, double clutch.
