got another question
Old May 14, 2006 | 09:29 PM
coolcat's Avatar
Default got another question
what other chevy cars can i use a 350 from to put in to my camaro 89' rS
Old May 14, 2006 | 09:32 PM
IMAREALBOYNOW's Avatar
Default RE: got another question
u can use any 350 from any car if u really want u can even use a truck 350 if u wanted
Old May 14, 2006 | 10:01 PM
coolcat's Avatar
would i get the same power though
Old May 14, 2006 | 10:36 PM
TimmyTheWop89's Avatar
overall, a 350 is a 350. the difference between a trucks 350 and a cars 350 is a truck 350 will have a low end cam and a low end manifold along with certain heads. you can turn any 350 into what you want. you can turn a 350 with 190 horsepower and 360 ft lbs of torque into a high revving horspoewer machin with 500 horsepower and 350 ft lbs of torque. its all what your wallet can accomodate.
Old May 17, 2006 | 02:11 PM
coolcat's Avatar
alright i finally figured it out with the 350 thing, i found a 350 off another camaro, i'm going to put an entire 383 stroker kit from northern auto parts what do ya think? the enginge runs, but i minus well make it run better by taking it apart and putting the crank, cam lifter set from crane, pistons etc....
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
