Good deal for a 9 bolt?
http://cgi.ebay.com/ebaymotors/CAMAR...spagenameZWDVW
Found this not too far from me, a couple days left and no bids. 3.27 gears and it is def. a BW 9 bolt. I have a few questions though: Is this rear really any better than my 10 bolt LSD? What are the pro's/con's about it? Did all of the BW's come with the larger rear discs, or are the older ones the smaller, opposite side set up?
RE: Good deal for a 9 bolt?
The BW could be found as early as 85 but the better brake set up (Not the stagered like those are in the pic) was from 89+. The BW would have a larger stronger gears that your 83 has. But for $5 bucks you could get that in scrap if you had to.
Im thinking about it, but im almost broke, what money I have left is going into the cherokee. My plan for it would be to get some 3.73 gears and clean it up, would be nice to swap it into the Z someday... I think I may just wait till after I get a new cam and heads, then if I break the 10 bolt I could justify it, haha.
xStangHater07x
02-22-2007 04:23 AM
