gauge cluster help
gauge cluster help
some of the bulbs are shot in my gauge cluster
and i can not find a list anywhere that tellswhat type ofbulbs they are
so if anybody knows what type they are and where to get then i would appreciate it
thanks
Brad
thanks
Brad
Dash indicator lights:
Headlight high beam: 161
Directional signal: 194
Temperature: 194
Battery: 194
Brake: 194
Fasten seat belts: 194
Check engine: 194
Oil pressure: 194
If your bulb isn't on the list then try to read the # on the burnt out bulb, chances are its a 194 or 161.
Temperature: 194
Battery: 194
Brake: 194
Check engine: 194
Oil pressure: 194
