Fuse??
Old Aug 22, 2006 | 04:12 AM
Deezil13's Avatar
Default Fuse??
Ok I am getting really frustrated with my new neon that i installed the other day to show off my club sticker in my rear window. When i was installing it i accidentally plugged in the wire to the BAT fuse plug on my fuse box and when i was fishing the wire through i didnt get to far when SPARK i get a spark right infront of my face from the fuse box. I pulled all the fuses and they are all good. I dont know what could be the issue can anyone please help me!?
Old Aug 22, 2006 | 04:31 AM
MadMikeZ28's Avatar
Default RE: Fuse??
The spark was in front of your face and you did not keep your eyes open to look.
Does everything still work? Are there any breakers on your fuse panel? Maybe one kinda overloaded and sent an arc.
Old Aug 22, 2006 | 04:34 AM
Deezil13's Avatar
Default RE: Fuse??
Well my hatch switch to open the hatch doesnt work, and my stereo doesnt turn on. And no I dont see any breakers on the panel. I replaced the RADIO fuse on the panel but that didnt change anything.
Old Aug 22, 2006 | 04:38 AM
MadMikeZ28's Avatar
Default RE: Fuse??
UH OH
Maybe the spark was from behind the fuse panel and a wire burned or broke. Is it hinged on your were you can pull it far enough forward to squeeze your head in and look?
Old Aug 22, 2006 | 04:52 AM
Deezil13's Avatar
Default RE: Fuse??
All the wires on the back of the panel look good. And ohh yeah my cigerette lighter doesnt work either. I know this because my radar detector isnt working :P
Old Aug 22, 2006 | 04:58 AM
MadMikeZ28's Avatar
Default RE: Fuse??
HMMMMMMM
Got a wire diagram? Maybe you can find where and what is in common with all those items that do not work any more. I think cig lighters are usauly orange wires for hot but I think they are independent of the radio. Not sure though. Some wire must have been getting hot and melted to something else and when the insulation melted enough BOOM!
Old Aug 22, 2006 | 05:03 AM
Deezil13's Avatar
Default RE: Fuse??
Could it maybe be a grounding issue? I dont know if that could be it but i thought i would ask
Old Aug 22, 2006 | 05:14 AM
MadMikeZ28's Avatar
Default RE: Fuse??
Grounds dont send a spark. A hot will when it meets a ground or another hot. its the fact that you hooked the light into the batt terminal on the fuse panel. On the fuse box that all hooks together to the orange wires for the radio, hatch release relay and cig lighter. May be seperate fuses but it all gets jumpered in the back of the fuse panel.
Old Aug 27, 2006 | 02:29 AM
trailerparktrash2009's Avatar
Default RE: Fuse??
is your horn working..cuz my moms camaro and my sisters beretta the ciggarette lighter and horn are together in the fuse box..
Old Aug 27, 2006 | 02:53 AM
Deezil13's Avatar
Default RE: Fuse??
Well i went over all of my fuses again and i blew the ACC fuse so it was an easy fix PHEWW!
izayuhgawd
Nov 21, 2011 09:24 PM
masonhoban
May 8, 2010 05:57 PM
ladybridgeport
Apr 5, 2010 08:44 PM
masonhoban
Nov 27, 2009 08:38 PM
vinnydc1
Aug 24, 2007 08:31 PM
