fuel pump relay
Old 10-16-2007, 02:06 PM
Gordon24Camaro's Avatar
Default fuel pump relay
Does anyone know where the relay is? I have an 89 305 RS
any help will be great
[/align]
Old 10-16-2007, 02:23 PM
blackz87's Avatar
Default RE: fuel pump relay
Picture is from a TPI car, but since GM dose not change anything it should be at this location even for TBI. At least you will know what it looks like.
[IMG]local://upfiles/2696/4F370BFE8FC9470C84FACE4D65031885.jpg[/IMG]
Old 10-16-2007, 03:02 PM
thanks man
the MAF Power completely disinagrated, can that be the reason why the fan stop working?? But yeah my fuel pump is not working either even though i replaced it last year, but thanks alot
[/align]
Old 10-16-2007, 03:35 PM
mkdubs's Avatar
is there good wiring diagrahm online so i can trace the fuel pump wires?
Old 10-16-2007, 07:06 PM
checked the relay, the fuse thats next next to the battery, all the other fuses, and the pump still doesnt want to turn on when i turn on the electricity in the car? I changed it last year, i dont see how it could have gone bad so soon? Can someone help me figure out what can be wrong if its not the fuel pump?
[/align]
Old 10-16-2007, 08:31 PM
Arizona Camaro's Avatar
Assuming you can't here the pump when you turn on the key
Try jacking up the rear of the car and checking for power at the fuel pump wireing harness. (located right above the rear U-joint)
Pull the plug and find 3 wire ends.Get a voltage meter and stick your probes into the first and third one. If your getting voltage when the key is on (I think it should be 11 volts) then your pump is bad.
Old 10-16-2007, 11:48 PM
mkdubs's Avatar
so im having the same problem Gordon24camaro is, i did all the tricks you guys mentioned here and when i did the three plug test with a voltage meter i got nothing! so somewhere i have a short. but i cant find a good wiring diagram that shows which wire goes where
Old 10-17-2007, 12:33 AM
I think then you have to start checking things upstream. Like the relay and the fuseable link by the battery
Old 10-17-2007, 09:30 AM
mkdubs's Avatar
ive already ruled them out, the relay send power out like it supposed to, and theres power running threw the fuse like normal.so its some where between that and the pump
Old 10-17-2007, 08:01 PM
yup, theres something a miss between the relay and the fuel pump. I changed my fuel pump last year, i just dont see how it could have gone bad, but when i checked the relay the wires were a bit loose, but still doesnt explain it how it did a sputtering deal the last time i drove it. I think im just gonna take it to a mechanic
[/align]
Quick Reply: fuel pump relay
