Fuel Problem
RE: Fuel Problem
That brings up a question. This was a TPI car? And you replaced it with TPI? If memory serves they are at different pressures with the TBI. +1 on what 86Z350 Most likly its the sending switch/connection. Have you started the car? Pump should run for about 10 seconds when the key is turned on then shut off ifthere is nooil pressure.
