finding a pitman arm for 91
Just to be sure, you are referring to the arm from the steering gearbox? Ive got one laying around. It came from an 82. I dont know if they are interchangeable. Do the research, if it fits you can have it for cost of shipping.
as far as I can tell the pitman arm will only fit 87-92, so thanks anyway.
I have a couple of inches of play in the steering wheel and have figured that it is because of the pitman arm but I can't find a replacement anywhere. could it just be that it needs to be tightened or something?
thanks for the replies.
I think that's what the confusion is. The steering wear items on your car is an idler arm, inner and outer tie rod ends, and center link. Which all looks like this: http://www.youngsfbody.com/inc/sdetail/7406
The idler arm is that bell-crank looking piece.
All you need to do is run the engine while the car is in park, and look under the car while someone else is rocking the steering wheel left to right. You'll be able to see which parts are sloppy because they'll rock before they move the linkage. It's also not uncommon for tie rod ends to go out as well. It would be better to look so you know exactly which parts are worn, instead of just throwing new parts on with the hopes of it being the right one.
20 yr old car and if the steering parts are original, I would not just replace one part at a time. If you plan on keeping the car, I would replace everything and it would tighten up the steering after a ft end alignment. Replaced all my 23 yr old original steering parts on my car with these. After there was a vast improvement in feel and steering control.
