Finally Started
#21
RE: Finally Started
I had an open 3:43 with the early rear disc. I changed it to a later 2:77 with the better caliper set up. From that change launch would be worse but it was not really noticable. What was noticable was the better MPGs. I even run the differences on my desktop drag strip and it made only a very small change in the times
#25
RE: Finally Started
motor is finally completely dissasembled. crank bearings look ok and so do the rod bearings. BUT, i might replace them anyway since im there. All of the bearings are .020 over stock size. i didnt see them in a jeggs catalog. but im sure i can get them at a local parts place that has stuff that autozone and places like that wont.
#26
RE: Finally Started
forgot.. when i took the timing chain cover off there were ceramic like pieces all over. closer look and they were up in the oil pickup and everything.. what is that? ive got pics if you need them
#28
RE: Finally Started
na, its a steel double roller setup. I asked my dad about it. he said it might be left overs from when it was rebuilt that didnt get cleaned out properly or something.
