-   82-92 General (https://camaroforums.com/forum/82-92-general-10/)
-   -   F & R Spring dimensions (https://camaroforums.com/forum/82-92-general-10/f-r-spring-dimensions-34037/)
aussiesmg Dec 20, 2008 02:28 PM
Hey guys, has someone got a set of stock front and rear springs laying about?
I need the diameter of the top and base and overall length please, I am having a custom set made and need the basics before i pull mine apart
hevymetalg Dec 20, 2008 02:50 PM
RE: F & R Spring dimensions
car,yr,engine?
350rs Dec 20, 2008 03:58 PM
i have all 4 sitting in my shed. if its for a v8 ill run out there and check them for ya
aussiesmg Dec 20, 2008 08:50 PM
Yepper its an 85 V8
350rs Dec 21, 2008 12:11 AM
might be able to get those to ya monday, but that would be as soon as i can do it man. when do you need it by?
ScottD Dec 21, 2008 02:10 PM
Aussie, here are some rough measurements:
Front springs, measurement taken from my OLD beat up ones: 5 7/16 OD, 4 ID, approx 14 OAL. Like I said, they were pretty whooped and I think my freshly installed ones were almost an inch longer.
Rear springs: brand new aftermarket springs waiting to get installed as soon as I find new isolators. 5 1/4 OD on top (bottom is reduced) OAL approx 16". Lemme know if you need more.....exact measurements are tough when its 22 degrees in my garage....
aussiesmg Dec 22, 2008 04:59 PM
I could use the ID/OD on the lower end of the rear, and are these stock height new springs? That should do it. I am having some built with a couple of extra inches length so I can rally the beast, offroad = more travel. Thanks so much guys.
Steve
ScottD Dec 23, 2008 03:43 PM
The very last coil is signifigantly smaller than the rest. This is the coil that rests on the platform on the axle. Its about 3 ID and 3 1/2 OD. These are OEM springs. I measured the ones I just took out, but the IDOD of the new ones were the same, the only thing that differed was OAL.....(old ones were pretty copmresed from age)
aussiesmg Dec 24, 2008 07:20 AM
Thank you, that's what i needed
