F & R Spring dimensions
Old Dec 20, 2008 | 02:28 PM
aussiesmg's Avatar
Default F & R Spring dimensions
Hey guys, has someone got a set of stock front and rear springs laying about?
I need the diameter of the top and base and overall length please, I am having a custom set made and need the basics before i pull mine apart
Old Dec 20, 2008 | 02:50 PM
hevymetalg's Avatar
Default RE: F & R Spring dimensions
car,yr,engine?
Old Dec 20, 2008 | 03:58 PM
350rs's Avatar
March 2008 ROTM
i have all 4 sitting in my shed. if its for a v8 ill run out there and check them for ya
Old Dec 20, 2008 | 08:50 PM
aussiesmg's Avatar
Yepper its an 85 V8
Old Dec 21, 2008 | 12:11 AM
350rs's Avatar
March 2008 ROTM
might be able to get those to ya monday, but that would be as soon as i can do it man. when do you need it by?
Old Dec 21, 2008 | 02:10 PM
ScottD's Avatar
Aussie, here are some rough measurements:
Front springs, measurement taken from my OLD beat up ones: 5 7/16 OD, 4 ID, approx 14 OAL. Like I said, they were pretty whooped and I think my freshly installed ones were almost an inch longer.
Rear springs: brand new aftermarket springs waiting to get installed as soon as I find new isolators. 5 1/4 OD on top (bottom is reduced) OAL approx 16". Lemme know if you need more.....exact measurements are tough when its 22 degrees in my garage....
Old Dec 22, 2008 | 04:59 PM
aussiesmg's Avatar
I could use the ID/OD on the lower end of the rear, and are these stock height new springs? That should do it. I am having some built with a couple of extra inches length so I can rally the beast, offroad = more travel. Thanks so much guys.
Steve
Old Dec 23, 2008 | 03:43 PM
ScottD's Avatar
The very last coil is signifigantly smaller than the rest. This is the coil that rests on the platform on the axle. Its about 3 ID and 3 1/2 OD. These are OEM springs. I measured the ones I just took out, but the IDOD of the new ones were the same, the only thing that differed was OAL.....(old ones were pretty copmresed from age)
Old Dec 24, 2008 | 07:20 AM
aussiesmg's Avatar
Thank you, that's what i needed
Cracked Heads
Jul 14, 2015 04:26 PM
mutlyi4
Jan 12, 2013 10:34 PM
92camaroRS
May 6, 2008 10:40 AM
maudyZ28
Mar 14, 2008 07:16 AM
RTCrunelle
Mar 13, 2008 06:31 PM
