Engine Speed***(RPMS)
Old 05-02-2009, 08:44 PM
CADGA1390's Avatar
Question Engine Speed***(RPMS)
Hey everyone, my brother and i got our 1989 Camaro yesterday! and we've driven about 150 miles already (hehe, couldn't stop) and on GA-400 and I-285, i noticed that even in overdrive, the car revs awfully high from what i'd expect. at 70-75MPH it was running 3000RPM to 3500RPM. Maybe its just me and what i'm used to from our other cars that run those engine speeds at 90-110MPH in overdrive. So i was just wondering if this is normal, or what, and to see what engine speeds ya'll are running at 70-75MPH. THANKS!!!
Old 05-02-2009, 10:19 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
What engine do you have? RS or IROC-Z? Auto or manual?
Old 05-03-2009, 07:51 AM
blackz87's Avatar
3000/3500 RPM's @70/75 MPH is way too high for a 700R4 in OD. Way too high no matter what engine or gear ratio you have. The 700R4 is not locking up in OD at those RPMS and speed.
Old 05-03-2009, 08:06 AM
84 Z28 Bowtie's Avatar
Sounds like either the trans is slipping
or
Previous owner replaced your rearend gears with a higher ratio to make the car a little peppier off the line.
Old 05-03-2009, 08:51 AM
blackz87's Avatar
or
Even if the car had 3:73 or 4:11 gears (slim to none) the RPM's are still to high for the 700R4 in OD.
Old 05-03-2009, 11:02 AM
CADGA1390's Avatar
hey everyone, thanks for the replies! The car is an 1989 RS 305V8 w/ the 700R4 trans. The rearend has been changed, but not even the previous owner knows the ratio. Also, he had a guy in NC do some tranny work on it. All I know about that work is that it has a bumper kit on the 1st to 2nd shift that makes it shift hard, and if on the throttle hard enough it'll. Chirp the rear tires into 2nd. I'll ask him and see if he knows those peoples numbers so I could call and see what they did, because I don't like the engine running those speeds at that low of speed. Maybe I'll male a vid of it going through the gears so y'all can have a better idea.
Old 05-03-2009, 12:15 PM
blackz87's Avatar
Shift kit has NOTHING to do about the tranny shifting into OD and locking up.
Old 05-03-2009, 12:36 PM
mtn_maro's Avatar
it sounds like its just not shifting into od. go up to those speeds and count the shifts
Old 05-03-2009, 02:12 PM
blackz87's Avatar
Easy test for lockup. With the transmission in OD, drive at steady 40mph and at this speed the Tach should read 1000 RPM's, if the transmission and Tach are working correctly.
Old 05-03-2009, 03:01 PM
CADGA1390's Avatar
Hey, I have counted the gears, and put it in non-overdrive, and then shifted into overdrive. Trust me it's going into overdrive. I think that the rearend ratio is just really high. I calculated it and the rearend would have to be a 4.69 for the engine to run those speeds. And at a steady 40MPH it runs ~1750RPM. I don't know what the deal is, but I hope to fix it soon. I don't want the MPG or anything else ruined by those higher RPM's when cruising.
Quick Reply: Engine Speed***(RPMS)
