engine shutting off problem
Old 02-26-2007, 07:02 PM
Default RE: engine shutting off problem
Really, check that the air cleaner is clean, Have you looked at the Idle AIR Control valve, and Throttle Position Sensor?
Old 02-26-2007, 08:07 PM
Shmack2004's Avatar
replaced the IAC valve, the TPS is fine, K&N filter.
could it be a clogged cat?
Old 02-26-2007, 09:20 PM
It is a possibility, it's been there long enough.
Old 02-27-2007, 12:11 AM
Shmack2004's Avatar
well before i tear apert the exhaust i found some kind of sensor (possibly air temp?) on the air filter cover that is not connected and a few wires goint to nothing (looks like a temp sensor plug, and another plug with a resistor on it. and a stray wire.)
Old 02-27-2007, 12:43 AM
Looks like one the mods being sold on E bay. lol
Old 02-27-2007, 03:06 AM
FlufyTiger's Avatar
It's probably someone trying to fool the PCM into thinking it's got a dense charge of air. If you've got a scan tool handy, try checking out the Intake Air Temp. If it's just an open circuit, it'll read at -40 degrees, otherwise, the resistor will probably read something completely inacurate. Then try plugging the sensor back in. If this is not the case, just plug the thing in and see if there's an improvement.[/align]
Old 02-28-2007, 12:05 AM
Shmack2004's Avatar
i cut the resistor thing off and now it runs like **** when you first start it, so i put it back on and it still runs like **** when you first start it.
Old 03-02-2007, 07:27 PM
350DREAMS's Avatar
check the air cleaner, word.
Old 03-04-2007, 08:27 PM
Shmack2004's Avatar
air cleaner is a fresh K&N
could it be a leak in the fuel return at the fuel pump?
  #20
Old 03-05-2007, 08:36 PM
Shmack2004's Avatar
someone told me today the it could be a problem from the factory from when they first came out with TPI.
he said some idling problem due to maybe a valve or the ecu. someone also told me about some valve in the exhaust where the 2 headers collect into 1 pipe. also someone else said it could be the egr valve stuck.
cibolaraider
82-92 V8 Tech
12-26-2014 12:03 PM
DarlingReject
04-02-2012 10:15 PM
husker_camaro95
02-03-2011 07:29 PM
Jose99
02-13-2010 11:35 AM
dcanada53
02-02-2008 09:51 PM
Quick Reply: engine shutting off problem
