Engine Light
alright have an 85 T/A engine light went on about a week ago after about 15 min of driving, then again tonight...what some possibilites be? Is there any place where i can get the code? AdvAuto said they dont have OBD1...
Thanks
Thanks
I think everyone that has a Hot Rod with a computer should invest in a code reader. It'll save You a lot of headaches. It shouldn't be too hard to find one. I bought Mine at AdvAuto.
Jumper the two black wires on the aldl connector (a+b wires) and turn the key on engine of and count the flashes. It cost a paperclip. first you will get a code 12. one flash..pause...two flashes. It does that 3 times them it will flash codes in the same way, three times each code. When it flashes code twelve again it is at the end of the stored codes.
Bend a paper clip and stick it in tha A&B terminals of the ALDL connector under the dasboard. You want to short the two black wires toghether (terminals A & B).
Connector pinout looking at the front of ALDL connector:
F E D C B A top row
G H J K L M bottom row
F E D C B A top row
did and it did nothing when i started the car up
but when i just turned it so the radio was on the engine light went on, blinked, then went back to solid......this any help?
