Edelbrock headers. Dumb Question. Help Please
Just got these headers, http://www.hawksthirdgenparts.com/ed...eaders50l.aspx
And like I said its a dumb question, but what are the valves openings for?
[IMG]file:///C:/DOCUME%7E1/Ryan/LOCALS%7E1/Temp/moz-screenshot-3.png[/IMG]
Emissions. Your A.I.R. pump check valve and hoses would connect to those fittings. Does that mean your factory AIR setup is m.i.a.?
If so, you'll need to cork those header fittings off with plumbing caps.
It's unfortunate the tubes are there, it makes the headers look a little less pretty. You can get the caps at your local hardware store, Home Dopey, etc. They are a NPT (National Pipe Thread) and are in the plumbing section. I found some shiny zinc coated caps when I once removed the air stuff, they don't look too bad.
slimstyle
05-07-2010 02:36 AM
