Does the Ecu control the following?
RE: Does the Ecu control the following?
Do i just go to oreillys and tell them i need a distributer for a 91 camaro? I need the exact specifics please. Also what is an opil pressure switch or is part of that a typo?
You need to tell them you want a non computer controled distributer. and an opil switch is the same as an oil pressure switch but it has a little "p" in it.
You have an iol pressure switch that already does this but I think it also works through the computer so maybe a little rewiring to use it without.
http://store.summitracing.com/partde...5&autoview=sku
What kind of modifications do I do to chokes and vaccums and linkages and all that **** to make this work?
I just did some checking and the oil pressure switch on your car will work without the computer. If you wanted to go this route you will have to hook a togle so it will run power when it is on but cuts off power from the oil pressure switch. It can be done but may be easier for you to just use a togle.
