A couple questions....
First of all.... I think I am the only one on this forum with a standard coupe and a 2.8 liter v6.
I was wondering, is it worth it doing an engine swap and all that other good stuff? Also. I just bought the car and they had just put a non performance exhaust so I was also wonderingif I put a flow master on it, would it fit into a 350? |
RE: A couple questions....
to answer your first question, let me ask you one. do you intend on having any sort of fun with this car or is it just a car to get to and from work? if fun was your answer, then yes, swap the engine and trans. for your second question, are you thinking flowmaster cat back? because if you are only doing the cat back when you put the 350 in the car, the headers y-pipe and intermediate pipe (from the y to the cat) will all have to be changed accordingly. my advice, if you plan on doing the swap, wait till after the motor and trans are in, then worry about exhaust.
