Coolant questions
Old Jan 2, 2009 | 10:55 PM
BlueKitsune's Avatar
Default Coolant questions
Ok well AS I pulled my intake off I saw that the walls of the coolant passages have this red kinda gunk like stuff on them and Does that mean Im rusting out somewhere? OR did someone try to use dexcool in this engine? ( theses dont use dexcool...right?)
Old Jan 2, 2009 | 11:10 PM
rockin85's Avatar
Default RE: Coolant questions
well i dont know what dexcool is but i do know that when theres water on metal it will rust. if your heads are cast iron, you will see some rust in there. im not sure if it would be caked up but i have found chunked up antifreeze in my old 305 heads. i just chipped it up and cleaned it.
Old Jan 2, 2009 | 11:19 PM
Dexcool is what newer GM Cars use (Ever seen red Antifreeze? thats it)and ya I have iron heads so your probably right it is rust I'll probably go get it power flushed and pray it doesnt blow up the radiator or something thanks to the rust
Old Jan 3, 2009 | 12:23 AM
Actually, Dexcool is orange.
It's not so unusual to find a small sludge mine when you open up the engine. Chances are pretty good that your engine's cooling system hasn'tbeen flushed, or back-flushed very often...or maybe not at all???
Flushing the system and changing the coolant regularly will help avoid getting a build up like that. But how many car owners are actually that religious about changing their coolant? A small percentage I'm sure. It's kind of a forgotten "ain't broke, don't fix it" maintenance.
Old Jan 3, 2009 | 12:25 AM
irocktheIROC's Avatar
hey maro69 does your 69' have powersteering or brakes??? just a dumb question...
Old Jan 3, 2009 | 12:36 AM
ORIGINAL: irocktheIROC
Not a dumb question, but nope, neither. The only time I miss power steering is when parallel parking. ButI don't parallel park very often as it is. I eventually want to convert it to rack & pinion anyway. And the car stops just fine using"the harder you push the faster it stops" method.
Old Jan 3, 2009 | 01:03 AM
lol Nice, and it looks like its never been flushed aw well
Old Jan 3, 2009 | 08:55 AM
ScottD's Avatar
Dont sweat it. Do a flush if you can. Most older cars have this kind of build up. Nothing to worry over.
Old Jan 4, 2009 | 01:59 AM
Hmm Ya I will, I still have to go get new intake manifold gaskets (I cant believe it wants me to use stock GM gaskets! I cant use Felpro or Mr. gasket it seems) Aw well, Paint the EGR Crome, clean all the old line fittings and get a new water neck, coolant temp, thermostat then plop on my custom TBI I made!
Old Jan 4, 2009 | 02:42 AM
c4maro's Avatar
Dont forget to take a pic of that TBI, im intrested in seeing it.[8D]
