Computer/passkey issues. 89 iroc z
Old Apr 10, 2009 | 10:22 AM
bezerker's Avatar
Default Computer/passkey issues. 89 iroc z
So last month I bought this beautiful blue iroc z. New parts all around, couldn't find a problem until we took it for a test drive. Wouldn't idle right, and bucked a bit almost like a misfire when at 1-2k rpm. After about a week of replacing everything we could I called the guy I bought it from back and described the problem. He owns a racing shop where he does nothing but work on these TPI cars and offered to fix any problems I found for free as he sold it turnkey for 4500.
Anyways, turns out the problem is that the computer in there is from a 350. It's a 305 in the car. Obviously too much gas.. He still has the original computer but cannot use that since he swapped the anti theft system because the old one took a crap. Apparently swapped with one from another year car. I don't understand much about the anti theft system, but I do know I need the key with the resistor to start the car.
Now my question is as such: I really do not care too much for the anti theft system. The car has been sitting a month now because he cant find a 305 computer to work with the anti theft system. (I don't know the details about the system as I didnt have the car long enough to look.) At this point I'm wondering if it's just possible to gut out the anti theft system completely without buying replacement parts ? It might be faster....
Is it a pain? When I suggested that idea to them they seem to have brushed it off which made me wonder how much work is involved.
Edit: I'd also like to try to gut this out without any crazy codes firing all the time, or issues occurring.
Thanks,
Bez
Old Apr 10, 2009 | 12:50 PM
blackz87's Avatar
The ECU (computer) is the same for a 305/350 TPI, but the Prom (chips) are different. My understanding of the Vat system (vehicle ant-theft) is in the key (chip) and not controled by the car computer. Wrong key or a wore key will result in the car not starting. My opinion is he is giving you the run around.
Old Apr 10, 2009 | 04:55 PM
bezerker's Avatar
So.. just got off the phone with the gentleman.
Basically, The vats crapped out so he stuck a computer from an 87 5 speed in there but it had a 350 prom.
Which explains all sorts of problems I've had. 89 had no cold start injector , which ill bet the current replaced ECM is looking for.
I THINK all I need now is a PROM for an 89 305 5 speed TPI without VATS. But I'd rather just find a whole damned new computer w prom.
he tried one from an auto but the shift light stayed on nonstop. heh.
Old Apr 11, 2009 | 06:00 AM
blackz87's Avatar
Forget about the expense of new ECU it will not help. You need a Prom for 1989 305 sp and my guess they are unavaible. . Try Fastchip.com for a custom chip for your application. One of the problems when you buy a Franken Car that someone chopped up.
And again the ECU dose not control the Vats system it is in the KEY....Do a search on Google, so you will understand
how the Vat's system works on your car.
Old Apr 14, 2009 | 09:09 AM
NEVERLETITDIE's Avatar
you can just get a new pro or chip and it should fix all your problems
but the guy is putting you through a bunch of bull
and just because he owns a racing shop doesnt mean he knows it all
Old Apr 15, 2009 | 12:29 PM
Jr. Mechanic's Avatar
August 2009 ROTM
IIRC, there is a write up around here somewhere to disable it. It involves pulling the steering column apart, and matching a resistor to the PROM in your ECM.
Old Aug 8, 2010 | 08:07 AM
jamesalshaw's Avatar
learn more about Backlinks by joining a Backlinks Forum .Hopefully it will all make sense sooner or later. 2291-1buckplr finally more finally
Old Aug 12, 2010 | 11:06 PM
lbrendanwalkerq's Avatar
Old Aug 13, 2010 | 10:25 PM
Old Aug 14, 2010 | 08:01 AM
blackz87's Avatar
Originally Posted by lbrendanwalkerq
remove....
