colum issue *update* fixed colum but gauges dont work!!!
Old Nov 1, 2008 | 03:57 PM
1989_RALLYSPORT's Avatar
Default RE: colum issue an some other questions
yeah i now have an unknown battery issue...the bat is fine if it sits for days but if you run it an try to start it back up like an hour later its dead till i get a jump an its good to go ive came out to a dead car only 2 times an both were within 2 hours of previous driving.... odly enough when i run it an then park it over night right after the dead bat prob the battery will be just fine and fire right up the next day
Old Nov 1, 2008 | 07:00 PM
MadMikeZ28's Avatar
Have you tested the alternator? I have had my battery go dead before from playing the stereo and after letting it sit for a while rejuvinate itself enough to start the car. AC Delco batteries have been good to me that way. Or possiby your starter gets hot and won't crank the engine well enough.
Old Nov 13, 2008 | 06:57 AM
well it always cranks slow.
and the alt is a rebuild with the 1 wire conversion and the + fromt the alt is ran direct to the + on the bat
odd thing is its been doing it more lately that when i go to the store i dont shut it off anymore
but when it does do it i can usually jump the solenoid and it will turn over slow like usual an fire
i think ill be going out to buy an optima red top bat soon
Old Nov 13, 2008 | 07:21 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Next time it does it, have a load tester handy, the only right way to determine if it is the battery or starter. Could even be loose connections somewhere.
I doubt its a big issue, but was the alternator wire ran to the battery orginally? I know generally it will run to the distribution block on the firewall.
Old Nov 13, 2008 | 10:22 PM
ORIGINAL: Jr. Mechanic
i think p/o had it ran to the + on the starter originally
Old Nov 13, 2008 | 11:45 PM
MadMikeZ28's Avatar
At times there would be a junction block with one of the wires going to the starter. 89 might have it by the battery. Or might had been there.
Old Nov 14, 2008 | 02:42 PM
yeah the core i put into my camaro had a block it was damaged though but my wiring has been riged to bypass. p/o took a huge wire nut -_- an twisted a ton of heavy gauge wires together an screwed on the wire nut. i am going to autozone today to get a block and run all the wires through it as the wire nut look is ugly as all hell with its bright orangyness and tons of black electrical tape...
some peoples kids.... shouldnt every father teach their sons to work on cars?![sm=rant.gif]
well mine didnt...i learned on my own starting with lawnmowers when i was 5 and quickly progressed
Old Nov 14, 2008 | 06:23 PM
MadMikeZ28's Avatar
I have a friend and his daddy learned him to use wire nuts real good!
The funny thing was he is left handed and could not for the life of him twist the wires clockwise. He had to get me to do it for him so he could put the wire nut on. [8D]
Old Nov 14, 2008 | 08:01 PM
Mike, I never pegged you as a nut-twister. Go figure!!![8D]
Old Nov 14, 2008 | 09:56 PM
  #20
MadMikeZ28's Avatar
I did not twist the nuts....Just the wire.
