clutch release problem
here is the back story. transmission went bad so i replaced it. in order to do that i took the hydraulic slave cylinder off of the bell housing so i could remove the bell housing and now my clutch will not release all of the way.
i purchased a Zoom Performance Products 30009 - Zoom High Performance Clutch Kit what is going on. i would like to get this fixed asap. |
have someone step on the pedal and crack the bleeder screw a lil bit to releave some pressure.
You'll need a helper to fix the problem. One person to push the clutch in, and another to open the bleed screw. Once the cluth is depressed hold it down and then open the bleed screw. Close it before releasing the clutch pedal, and repeat this 3-4 times. After that all should be fine again.
thanks a lot guys im going to try to get my brother to help me today sometime.
well i bled my clutch and im still having issues.
when the car is in the air the clutch fork will move about a inch but when it is down on the ground it only moves about half an inch. |
any more suggestions
i dont see how the travel is being affected by the car being up in the air. are the forks properly over the release bearing? is the fluid level full in the master cylinder? dont just look at it because the old fluid will stain the resivior. open it up and look inside.
Check the static adjustment before the clutch is depressed. How much freeplay do you have in the arm?
