The clutch pedal
Old Mar 4, 2007 | 12:42 AM
Gordon24Camaro's Avatar
Default The clutch pedal
Today i was crusing and as i went for the clutch I didnt feel any pressure at all when i pressed it in asyou usually would feel. And as i went to put it in 1st, the gears grinded. Is my clutch going or was it just some random incident? Thanks
Old Mar 4, 2007 | 03:54 AM
350rs's Avatar
March 2008 ROTM
Default RE: The clutch pedal
check your fluid levels for the clutch. if low, use standard brake fluid to fill it back up. if thats not it, either your clutch master cylinder or the slave may have gone out. check for leaks. if all checks out there. your clutch has gone out my friend.
smokefan
Jul 19, 2010 06:28 PM
80rsguy
70-81 V8 Tech
Mar 28, 2009 04:04 AM
Skippysnax
Mar 3, 2009 12:09 PM
hascet
Jul 4, 2008 03:19 AM
brandino
82-92 V8 Tech
Jul 9, 2007 01:21 AM
