-   82-92 General (https://camaroforums.com/forum/82-92-general-10/)
-   -   Clutch installation (https://camaroforums.com/forum/82-92-general-10/clutch-installation-14376/)
85z285.0 May 16, 2007 05:45 PM
Clutch installation
Hey gang I just picked up a Centerforce DualFriction clutch and Throwout Bearing from Jegs. I was wondering what advice, tool recommendations, or any insight you may have in the removal and installation of this clutch. All advice welcome thanks a million.
1985RS May 17, 2007 01:42 AM
RE: Clutch installation
well when your putting the clutch up, make sure you use the alignment tool that came with the clutch, and torque the pressure plate in sequence to avoid warpage, other than that, take your time, make sure you dont press the clutch pedal with the trans out, and dont drop the trans on yourself and all should be good
