-   82-92 General (https://camaroforums.com/forum/82-92-general-10/)
-   -   changeing header gasket (https://camaroforums.com/forum/82-92-general-10/changeing-header-gasket-14074/)
350rs May 8, 2007 08:50 PM
i bought some of them copper gaskets. im gona put them on tonight so i need info ASAP. Anything other than the actual gasket necessary? and the obvious bolts... any kind of sealant? the old gasket or something else?
microkid May 8, 2007 09:07 PM
RE: changeing header gasket
as far as i know, you shouldnt need anything else. i would recomend a thin film of red high temp rtv if you want a very good seal.
350rs May 8, 2007 09:10 PM
thats what i was thinking, put a thin strip on both sides, cant hurt...
1985RS May 9, 2007 01:30 AM
if your using copper gaskets, i wouldnt use any sealant, its unnessecary. however, for your own piece of mind if you want to use a sealant, just put tiny dabs along the perimeter of the gasket and smooth it into a very thin film evenly covering the gasket
