Can you?
RE: Can you?
Well I was planning on putting like a adjustable 4 barrel double pumper on there with interchangeable jets. But in doing away with all that stuff how would it affect the vats ****? Remember its tbi (throttle body injection).
RE: Can you?
The VATS stuff won't work without the computer, but it can be wired around to provide power to the fuel pump, also you may have to replace the distributor with one that is not controlled by the computer.
RE: Can you?
So id have to hard wire the pump and find a non-computer controlled distributor and I should be set to go right? Is there anything else you can think off that would need to be "modified" to run the car without the computer?
