Camaro Door Locks
Old Nov 28, 2009 | 01:42 AM
thomasstuart's Avatar
Default Camaro Door Locks
I own an '86 Camaro and recently tarted to have a problem with the door locks. Initially, the drivers side door opened normally but when I went to shut it,the latch mechanism (a sort of "U" shaped rotating part) would not turn to engage the pin (i.e. let the open "U" over the pin) on the door frame...so the latch just bangs against the pin. Next, I violated my usual principle of "if it aint broke.... etc", I played with the passenger door and, to my dismay, managed to rotate the "U" part of the latch backward so that now it also is stuck in a position where that door also won't shut. If anyone (even another GM model owner) has any ideas how to free up this mechanism - preferably w/o disassembling the door trim - I would be eternally grateful.
Old Nov 29, 2009 | 10:36 AM
blackz87's Avatar
To correct your problem it is a easy fix requiring NO TOOLS...Solution: Hold the outside door handle in the open (UP) position and at the same time move the "U" shaped hook with your finger to the correct position. Problem solved.
1994chevycamaro
Mar 8, 2009 11:12 PM
markcamaro
Aug 23, 2008 04:33 PM
streetrace06
Jun 29, 2008 05:03 PM
dnulnarts
Mar 6, 2008 03:51 PM
