cam, intake, heads
so i was considering a new intake, cam, and heads. i know that they will all fit my motor, but will these all work well together. (edelbrock performer tbi intake, comp cam extreme engery cam, and sr toquer heads) thanks
http://store.summitracing.com/partde...p;autoview=sku
http://www.jegs.com/webapp/wcs/store...tegoryId=11935
http://www.worldcastings.com/prods_pages/042660.htm
I've been looking at this setup:
Takes the guess work away!
hey 92camaroUK, you do know that that package wont work for your car or mine. it uses a carb. intake manifold, but it can work if you get an adapter plate. and "truly bad individual", thats tight as hell haha.
Intersteing point that onthe carb intake manifold....to be honest I hadn't noticed that[sm=oopssign.gif]
Cheers [sm=icon_cheers.gif]for the heads up.
To be fair I would have called Summit's technical team first.
I import all my parts from Summit. I have found them to be extremely knowledgeable and helpful each time I've phoned.[sm=smiley20.gif]
Here's the other information I have found out aboutthe Edelbrock Power Package (idle – 5500 rpm) - Engine Family305, 350 V8 T.B.I. 1987-95
Induction
- Intake Manifolds & EFI Systems (G) #3704
- Heads Cylinder (G) #60859
Valve-train
- Camshaft & Lifters #3702 (A,D)
- Timing Chains #7331,7800,7802
- Valve Springs (E) non-rotate, rotate #5802,5902
- Valve Spring Kits #5894
Accessories
- Aluminium Valve Covers w/Name #4246,4247(A)
- Water Pumps (G) #8881
Go this root and it will end up being a "Totally Bad Individual" [sm=burnout.gif]
Induction
Valve-train
Accessories
heads and intakeare pretty sweet. depending on what your wanting ... that cam is pretty lame. this cam would set those heads a blaze ... http://store.summitracing.com/partde...p;autoview=sku ... Sick
The adapter plate makes the two bbl TBI able to bolt onto a four bbl carb intake. Much better flow ratings can be obtained with the adapter and a good four bbl intake than with most of the TBI manifolds out there.
