blinker
blinker
ok i have and 85 camaro z 28. I have no speedometor wipers or blinkers. the only time the blinkers work is when i turn on the hazerds and even then only the left front and the right rear work. I replaced all the bulbs and checked all fuses. and to make things even more crazy is the arrows in the dash both turn on when i turn on when i turn the head lights on and only the left one blinks when hazerds are on or other wise they dont work. when i bought the car the guy said the interior was out of a 91 camaro
RE: blinker
ok i replaced the steering colom so far and i have all blinkers when i have my hazerds on and when i leave the key in it make the buzzing nosie which i didnt have before but when i want to turn left or right they still dont work and my wipers still dont work. I also was wondering what the box to the right of the colom under the dash is for cuz it looks rought all bet up. if inportant would the one off my 84 work?
RE: blinker
Before you do anything else replace the Flasher unit located under the dash to right of Steering column. It is a small silver colored cylinder or go to a parts store and ask for flasjer unit about $4.00. That should cure your problem.
RE: blinker
Do you even have the wrong cluster? Does it have round gauges? All your bulbs are good? all the sockets are good? There should be two flasher relays. One for the turn signals and one for the hazards.
RE: blinker
the thing with my cluster is none of my gages work inclueing my speedometer. and it is pluged into trany. so i was going to replace it with the cluster out of my 84
