any help??
any help??
hey guys new to the forum and im sure you guys have tons of info on this and earlier posts but here it is.
i am swapping to a 350. i had it bored over .03 with a new crank. rods. pistons edelbrock all. heads. 10:1 compression. stock five speed manual. im know i missing stuff also. im going to carb 750 with a torker intake. what problems will i encounter when i try to start her. im gonna try to use the stock fuel pump with a regulater... will it work? also can that ten bolt hold about 450 hp if i put new axels and a mini spool with 373 gears?
please any help would be awsome i will be dropping it in in about a month or so
91 camaro rs with 305 origanally.
