amp location
amp is 12"x8.5"x2.75". I tried under pass dash next to ecm, rear speaker compartment, under front seats, and spare tire compartment. I don't want to use the stash box on the drivers rear panel. I quess if all else fails I can build a box to hug up on the wheel well panels so I won't loose what little trunk space I have. I got this amp for free and just wanted to enhance my current 4 speaker system. No sub-woofs for me, I feel I'm alittle to old for the boom but thanks for replies.
Mine is about 10.5x10.5. But if you do not care about losing some space mount it in the well in back. That is where my box is located. I lost the space where my tire goes if I ever have to change it and use that spare but its all good.
And I am 40 and like the extra base. It sounds better that way. Unless you are listening to country then you need to turn the radio off for it to sound good!
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
well i have two 12's in a custom box that fits in the back well. i can still access my spare tire and stuff too. i jus mounted the amp and CD changer on the deck behind the backseat. i ran all the wires under the carpet up to the amp and CD changer. so you cant see any wires.
