alil advice
alil advice
hey wats up i have a 1986 camaro z28 and i wanna build up the motor alil bit it has the 350 tpi motor in it and i was wonderin if the lt4 heads wud fit on it wit no mods and wats the best kind of cam out there i wanna build a motor for all low end power and does anyone have any interior parts or any parts at all that they wanna sell and does anyone have any t-tops out there that they wud sell cheap because a tree went thru one of my t-tops
RE: alil advice
The LT1/LT4 heads use reverse cooling and some of the water passages do not line up with those of a regular small block causing coooling problems. You will be better off with a set of Vortec heads P/N 12558060, if you want to use GM parts, which fit the regular small block and make as much power as LT4 heads. You will need a manifold made to fit the Vortec heads.
sohcnick
03-25-2013 04:03 PM
Spartan66
11-02-2007 06:02 PM
1981camaroz28
10-23-2007 05:44 PM
