alignment measurements?
Old Oct 2, 2009 | 10:31 PM
BlueKitsune's Avatar
Default alignment measurements?
Can someone give me the alignment measurements for an 89 RS? I took it to the shop and now it darts and nibbles much worse then before...
Old Oct 3, 2009 | 08:32 AM
blackz87's Avatar
Front steering parts may be wore out and can not hold alignment, it is 20yr old car. Picture of parts that may require repacement
Old Oct 3, 2009 | 02:46 PM
Lets see theres a... Draglink, tie rods idler arm, adjustment sleeves, I don't see a pitman arm. Oh goodie around $500 in parts I bet. Anyways I still need the measurements for now. I think it was what 3/36in toe in?
Old Oct 3, 2009 | 03:43 PM
blackz87's Avatar
For your Info the Pitman arm dose not need replacement unless damaged .. . Ball joints are also there and it is only $343. But you can keep trying the front end alignment, but with worn parts the only one making out is the alignment shop. so good luck. The Toe In spec is 3/32".....
Old Oct 3, 2009 | 04:59 PM
Oh well. Thank you for the info! I'll worry about parts over winter when I cant drive it lol
Old Oct 3, 2009 | 05:50 PM
blackz87's Avatar
Spring, Summer, Fall and Winter are all the same to me about driving my car in Florida.....
Old Oct 3, 2009 | 11:40 PM
Nice!, well I checked the measurement, it seems to be right. I guess the only thing I can point at now is worn out parts
Old Oct 4, 2009 | 07:42 AM
blackz87's Avatar
You finally relized that parts do wear out and need replacement, went though all that this Summer. I am the orginal owner and keep my car in tip top shape, but I still can not prevent wear & tear on 22yr old parts.
I would suggest the steering kit from Spohn Performance....Good Quality & Price with one stop shopping for parts that actualy fit a 3rd car.
overhaul2
67-69 I6 Tech
Jan 14, 2012 10:36 AM
fuhhuayt
Jun 2, 2011 05:02 AM
mcmcmahon
Nov 22, 2009 08:55 AM
*Cristina*
Apr 4, 2008 09:22 PM
jb 79
Feb 17, 2008 11:17 PM
