AIR system removal
Old Jan 18, 2008 | 02:00 AM
pyrofire127's Avatar
Default AIR system removal
Is it safe to just remove the A.I.R emissions thingy and put a plug in the holes left in the headers?
Old Jan 18, 2008 | 11:25 AM
jdubs1813's Avatar
Default RE: AIR system removal
Well why would you want to do that if the headers have the AIR fittings? It's safe to remove them and it shouldn't cause any problems, it only has to do with emissions. You may pop a code though, especially since AIR hoses connect together at a point where there are a few sensors. Why do you want to remove it? Is it because your Cat doesn't have the AIR fitting on it?
Old Jan 18, 2008 | 12:31 PM
well yeah my cat doest. but mostly because its in the way. im going remove the AC and the AIR is just anything thing that keeps me from having a good open work space. and its not like i can pass inspection anyways....
Old Jan 18, 2008 | 06:26 PM
MadMikeZ28's Avatar
When I installed a serpintine belt kit on my 84 I did not have a pump for it and drove with it all off for a while with no problems at all. All it does is pump air and an electrical conection to open a soleniod to allow it to pump air when needed which I had unplugged and never got a code.
blink18236dude
Sep 7, 2024 06:17 PM
WIspartan1026
May 18, 2012 10:14 AM
jrgearhead
Apr 21, 2011 01:31 PM
SixShooterCamaro
Sep 10, 2009 11:25 AM
69camaro1
Oct 11, 2006 03:59 PM
