Acceleration question
Yeah, the D with the little box around it enables overdrive. Generally you'll want to always use that, unless you're in a driving situation where you won't want to use it. Descending steep hills, for instance, or towing a trailer.
It won't affect your acceleration either way; all it does is allow your transmission to use the overdrive gear. When you have an automatic, you're wisest just to let the transmission do its job and not try to mess with it.
