? about the torque arm strut mount
Im not really up on the third gen camaro's, so what im having trouble with is the info on the torque strut mount. I've read in some post that i can get the piece for my TH350 from B&M, but i cant seem to find what i need on B&M's site. So if anyone has a part# that i can refure to it would help a lot. (Please Advise)
RE: ? about the torque arm strut mount
I think you willbe looking forsomething like this
http://www.jegs.com/webapp/wcs/store...10002_12890_-1 |
Hey thanx (MadMikeZ28) for the info, im new to the camaro world, and believe ill enjoy my stay. The RS camaro that im going to purchace is rite down the alley from me, which is real clean. The motor in it as of now is a rinky dink 2.8 v6 thatwont run, were a 350sbc will replace it. Just trying to figure it all out so i know what im up against.
Since you have to change the trans any way to fit a small block why not just put a 700R4 in it? If it has one in it now the tail shaft housing will pull off it to go onto another 700 that bolts to the V8. Then you have a low first gear and 4 speeds.
If you still want to go with a 350 I stumbled onto this on as well.
http://store.summitracing.com/partde...p;autoview=sku |
Yeah i plan to use my TH350 that i built for the 76 GMC swb pu, i was working on. The tranny has been built to churp the wheels, with a TCI breakaway 2400 rpm stall. Summit has an adapter that fits onthe TH350 @ TH400's just for this set up for about $100 bucks. I was fixin to slap my pu back together, untill i ranintoa 91 camaro, which will be the new home for my fresh 350hp 355sbc.
