92 RS won't start Security System?
Old 11-05-2013, 12:46 PM
I have a 92 camero rs and my lights on dash are on the enegine will turn but wont run, I have removed the wire from battery and put it back on, and still nothing I have also tryed the door locks and nothing I also tryed putting it in D and N and try to crack it but the engine still turns but wont crack, I have a key chip and cleaned it but nothing and I have no blown fuses.. anyone have any ideas lol..
Originally Posted by HorizoN
Hmm. Security systems always seem to cause problems. I feel you, man.
I can't really think of much, after what you've tried. You're sure that all your connections, including battery terminals and the like, are good and tight?
If so, it'll take someone more knowledgable than I to help you, I'm afraid.
  #32
Old 10-15-2017, 11:47 AM
Gary432's Avatar
Default security light
I had to change my steering column out in my 1992 RS for State inspection reasons, the column came with a new key but wont let the car start the is there a way to reset the security or do I have to change out the ignition?
  #33
Old 10-16-2017, 05:56 AM
The VATs is system is looking for the resistance in your key. Check out youtube for how too videos. You can swap in your key cylinder, or you can measure the resistance of your old key and buy a blank with that resistor and have it cut to match your new key.
The other option is to eliminate the VATs system buy adding in a permanent resistor. Again see youtube for how too.
  #34
Old 07-20-2020, 11:14 PM
CromeImpala66's Avatar
Originally Posted by 92ttopRS
Guys, starter was starting to make noise. Was waiting till payday to get a new one. Today it wouldn't start. Turn key and it is just dead. No clicks, no crank. Got a new bench tested starter. Same problem. I'm thinking I have a security system issue that just surfaced at the same time the starter went bad. I cleaned resistor and reader in ignition switch with iso alcohol. Used spare key. Car won't start. All electrical works. So I don't believe it is a connection. Any ideas? I'm stumped right now.
Under dash power distribution box (under driver side kick panel) is burned out. Need to replace it. This box distributes power to the ignition switch, dash lights, starter relay, etc. PAIN IN THE *** TO GET TOO.
radicalride
06-10-2015 10:30 PM
James Thew
08-29-2012 10:03 AM
taninf
08-20-2010 06:13 AM
95redz28
03-18-2010 10:11 AM
Levithain
12-01-2008 12:38 PM
Quick Reply: 92 RS won't start Security System?
