'92 RS sputtering...
It's a manual V8TBI thatalmost has 180,000 on it and after driving for a while (until the engine gets hot) and I start to do stop and go... the car starts to jerk really hard when i push on the accelerator.I even hear severe sputtering sound coming from the muffler as the car seems not get gas and want to go. Im nottoo car savy but I have a feeling its either the fuel injectors (I had the fuel filter replaced a couple years ago). Anyone know what the issue migtht be?
RE: '92 RS sputtering...
Replace your fuel filter again. I do mine every other oil change. And if it has not been done in a while (based on how often you do a fuel filter, or do you even change the oil) do a tune up. I have had on bad spark plug wire on a V8 cause problems like yours.
ORIGINAL: Dan88IROC Z
If it's going away when the engine is warm, sounds like you have a spark issue. Check your coil, wires & plugs.
