92 3.1 v6 bad idle and miss firing when hot
Bought me a 92 rs camaro a week ago and have been having problems with it starting and running while it's hot bad idle and miss firing ultimately leading to the engine dieing and not start up unless giving it gas then it will spit and sputter until you stop giving it gas. I've replaced spark control module, spark plugs and wires,engine management model and coil and still runs like crap I'll link a vid of it running fine and then crappy. Thank you for the help
test your fuel pressure
You should re-title those videos running bad and running worse! ;)
My thought too is to check fuel pressure. Your fuel pump, although might be working some, may not be putting out enough pressure to push enough fuel past the injectors. My old 3rd gen had a deteriorated and split rubber pump to sending unit connector (inside the tank). Even though the pump worked, most of the fuel spilled right back into the tank. |
