89 rs vats
89 rs vats
Hi all,
Thanks up front for any help, I purchased a 1989 RS with 305 as a project car for my daughter and I. it has been sitting since mid 04 the battery was dead and of course no keys. Its VATs equiped and I did my homework. Thanks to this site. I purchased and created all the 15 resistor combinations, verified tolerences, cliped wires and have inserted a non vats key cylinder in column and have a new battery. I tested all the combinations waiting the required 5 minute interval between each.
My issue is the security light is constant when I turn the key to start. I hear fuel pump engage and see gauges react on all the combinations. I do not ever get an atempt to crank.
My question is what else can I possibly be doing wrong or missing? Can VATS lose its memory after such a long time with no power? Any ideas on what else i may need to check.
Thanks again...Eric
Thanks again...Eric
i have one that i keep just in case. the thing is u need to know the key code. without knowing that the thing is no good. im wondering if its in the wireing. u check all the fuses by the driver door and under the hood. the theft deterrant modual may be bad. have u got a dealer service manual for your yr and model. they are much better than chiltons or such.
What a p.i.t.a. Has anybody tried one of these yet? VATS Bypass Module
Cheap and effective, works well.
You do need to know your ECM model however to match it up. However, 89's did not come with that many different ones.
