89 Camaro RS electrical
Old 08-18-2005 | 09:02 PM
partsmore's Avatar
Default 89 Camaro RS electrical
Restoring an 89 For the son.... Oil pressure guage and temp gauge at pegged at top. someone installed an aux. mechanical gauge.
I have a new sender for both the guages - put connecting the temp sender and grounding it out to block doesnt change anything ON THE GUAGE.
I cant find the oil pressure switch. Also the nut hard wired the cooling fan motor (to the ign switch) and I would like to connect it back with the engine tem - is this the coolant sender on the front of the intake manifold?
Old 08-18-2005 | 09:33 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: 89 Camaro RS electrical
coolant sensor is under passenger side head, you must access it from under the car
Old 08-19-2005 | 01:57 PM
partsmore's Avatar
YES- i FOUND IT - AND PLUGGED IT IN - THE GUAGE IS STILL PEGGED,
the coolant sensor for the fans is on the front of the intake correct?
and with oil pressure sensor/switch is not by the distributor like I am used to....
Old 08-19-2005 | 03:56 PM
If the gages are pegged high, it indicates that the side of the gage towards the sending unit is grounded before the sending unit
Old 08-20-2005 | 02:20 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
THE SENSOR FOR THE GAUGE ITSELF IS UNDER THE DRIVER'S SIDE HEAD. MAYBE YOU SHOULD LOOK INTO A NEW CLUSTER.
CaliMuscle68
03-06-2017 06:33 PM
68Ride
03-19-2013 09:55 PM
keithskye
03-18-2013 06:52 AM
travis.joeris
11-02-2011 02:35 PM
Dave81Z
07-10-2011 12:36 AM
