89 camaro 305 tbi idles 1500 rpm
Old 02-25-2007 | 05:58 PM
missmy72ss's Avatar
Default 89 camaro 305 tbi idles 1500 rpm
i just bought my son his first car. i was told the prom chip was wrong for the car. what can i do to find out for sure before i buy anything to fix the problem? it idles at 1500 rpms and check engine flashes constantly. burns fuel like theres no to morow any suggestions as to what i need to do to fix this issue?
Old 02-25-2007 | 06:24 PM
FlufyTiger's Avatar
Default RE: 89 camaro 305 tbi idles 1500 rpm
If the check engine light flashes, it's pretty much saying "Turn me the f___ off now, and tow me to a mechanic!" Ussually if the check engine light is flashing, something with the emissions system is so bad that you're going to end up melting your catylitic converter. I'm not exagerating here, I saw a firebird once that was driven 2 hours with a flashing MIL, and whenthe owner (one of my genius friends, I'm sad to say) parked it on the grass, he caught his lawnon fire because the cat was so hot.Get it to a nearbymechanic with a Tech 1, or a good quality generic scan tool, and have them get you the information from the PCM. Do NOT take it to an auto parts store with a scan tool for this one, they ussualy know how to pull DTCs and little more than that.[/align][/align]Sorry to be the bearer of bad news, but it had to be done.[/align]
Old 02-25-2007 | 08:40 PM
85z285.0's Avatar
Listen to Flufytiger. He knows what he's talking about. A flashing check engine light means something bad is going on and it needs immediate attention. Bring it to a nearby shop that knows what there doing.
Old 02-26-2007 | 08:11 AM
Rooster88's Avatar
It kinda sounds like a problem I had w/ my 01 impala. When my light flashed, my car was idleing wrong, eating gas, and lost power. It turned out it was misfiring. Let me say this though, I am only 19, inexperienced, and my impala is extremely different from the camaro. Just thought i would put that out there...
Old 02-27-2007 | 12:56 PM
missmy72ss's Avatar
also has anyone had this problem before?
Old 03-02-2007 | 08:30 PM
350DREAMS's Avatar
change the spark plugs and wires might be a missfire
Old 03-03-2007 | 04:01 PM
84VarinZ28's Avatar
if that check engine light is flashing then u really need to get to a mechanic with a scantool soon like FlufyTiger said. theres not much u can do until u know exactly whats wrong and a scan tool will tell ya. u probably have a misfire thats causing ur car to run really rich and its endangering ur catalytic convertyer.
bizzmzn
04-07-2012 08:37 PM
camarocrazy1288
82-92 V6 Tech
02-17-2010 12:29 PM
jeff_blake
07-18-2009 04:10 PM
camarorz28
12-05-2006 08:54 PM
