882 cylinder heads
#22
RE: 882 cylinder heads
I know proform makes them, I think someone sells the vortec with screw in studs that will use guide plates they dont require self aligning rockers. I think you need to decide if you are going to stroke the engine and what type of cam you want. Stroking the engine adds compression and with domed pistons I would figure all that out before deciding on a head. Losing compression with a thick head gasket isnt always a good idea.
