88 rs camaro bogging down and running bad help please
![Unhappy](https://camaroforums.com/forum/images/icons/icon9.gif)
hello i own a 88 camaro and for the life in me i cant find out what is wrong with it ive been having this problem well i rebuilt a new 3.1 for it motor wise it ran great for 3 months and started acting bad ok when it turns on it might shut right off so i turn it back on runs fine at idel great at idel but when i press that gas pedal the idel dropps and runs like poop like bogging
That is of course a way to test for a leak but I'd need more details of your issue
^^^^Those are all things it could be and some good ideas. Also is your timing right? If the timing is too retarded it can bog down when you step on the gas. If you stomp on it and it has no power at all than it could be timing. If it acts like its gonna stall out at times then it could be a vacuum leak......but you say it ran great for three months so it shouldnt be timing unless you made an adjustment.
timming as in timming chain or timming as in distributer timming and also the motors new new u might be right on the fuel pump ile change the filter lated today but when i turn the key over i hear the fuel pujmp kicking in so idk but u might be right i havent changed it what are the odds of a clogged or bad injector
clogged or bad injector would make it misfire and either run rich or lean, depending on how it is stuck. that would create a noticeable shake. change the filter out and run it again and see how it is
