85 camaro radiator flush
Old 02-06-2007 | 05:02 AM
ohiocopper12's Avatar
Default 85 camaro radiator flush
85 camaro. not stock motor. vin shows a v6. this has a 305 2bl carb. radiator has that thick white icky stuff in it. whats the best radiator flush/cleaner for this. thanks
Old 02-06-2007 | 01:53 PM
Default RE: 85 camaro radiator flush
When they get like that, they should be taken out and to a radiator shop for professional cleaning, where the tanks are removed and the passages rodded out. However, it may be more economical to put ina new one. That white stuff could be old sealant or aluminum oxide. Probably because no antifreeze was used or it was not changed regularly, and aluminum parts got corroded.
Raven93
04-19-2014 09:51 PM
Jeepin
11-16-2011 02:26 PM
BoricuaHec01
LS Series Tech
03-15-2011 08:57 AM
triumph601
03-31-2008 10:04 PM
94CamaroSFI
08-03-2007 12:06 PM
Quick Reply: 85 camaro radiator flush
