82 4 speed trans
RE: 82 4 speed trans
ORIGINAL: 78 LTRS camaro
Ive got a 82 camaro v6 with the 4 speed i was woundering if anyone knew if an older 350 v8 will bolt up to the trans and motor mounts any help would be great
A simple search will show this question come up many times and the answer is always No. Older or newer you can not bolt a 90 degree engine to a 60 degree transmission.
