6 bolt 350
Old 10-27-2006, 11:30 PM
motor tec's Avatar
Default 6 bolt 350
i have a 6 bolt 350 an i was wondering if im going to run into a prob boltin the 700r off my 305 to it... i.e flex torqe convert ect?
Old 10-27-2006, 11:55 PM
uncle bill's Avatar
Default RE: 6 bolt 350
Where are the 6 bolts You are referring to?
Old 10-28-2006, 12:51 AM
motor tec's Avatar
there on the tranny side like were the flywheel/flex plate bolt on
Old 10-28-2006, 01:15 AM
uncle bill's Avatar
Is it a 1 piece Rear Main Seal ? You can tell by the back of the crankshaft. If the crank has an aluminum plate surrounding the crank, then it's a 1 piece ( '87 - up ) If that's the case, You can use the 1 piexe 305 flexplate / flywheel on it. Just make sure the starter is corresponding to the flywheel size. All of these engines have a 6 bolt crank.
Old 10-28-2006, 01:22 AM
motor tec's Avatar
ok my room mate said that it is a one peice rear main seal.. also it's a auto an i was told that it's a 700r4. so this should all bolt right up correct?
Old 10-28-2006, 01:25 AM
uncle bill's Avatar
If the 700R4 came from a 1 piece rear engine, then the answer is Yes.
Old 10-28-2006, 01:28 AM
motor tec's Avatar
well did the 91 rs 305's come with a one peice.. if so then it will work.
timopajala
02-22-2017 07:27 PM
MBlac649
06-17-2013 05:51 PM
MS69 YENKO/4-SPEED
06-22-2010 05:07 PM
bivens8314
01-10-2009 04:09 PM
gozzy341
11-04-2007 08:52 PM
Quick Reply: 6 bolt 350
