350 swap project
#22
update
ok im at a point where i need to make a decision of what i want my engine to do before i can start getting some work done.
i want low end torque i want my engine to top out at about 5,500 rpm. i started looking for a cam that will fit what i want to do.
also i am going with a carb set up for sure.
i also have a thread for picking some heads. would 327 double hump heads do what i want.
i have an email into this guy to find out what the cast # is on these.
here are some cams i found that i thought would fit what i want to do.
link 1
Link 2
Link 3
Link 4
let me know what you guys think.
Recondidtioned Heads from a 327 Double Pumper ...pre 1969
Also included are the Intake Manifold and the oil pan, $250.00
link 1
Link 2
Link 3
Link 4
#23
Update
found heads and a cam.
may not keep the heads just depends if i can find a buyer and some good aftermarket heads.
heads
casting # 3927186
date code is H278 - August 27, 1968
intake 2.02" exhaust 1.6" chamber CC 63.305
a little porting done to them.
stainless 2.02 in manley intake valves
metal viton seals
3/8 rocker stud
magnaflux by the shop that did the work
ended up costing $400 but still a good deal.
New stuff
Cam
Comp Cam
Part #: 12-210-2
Grind #: 268H
RPM-Range:1500 to 5500
Lobe-Center Angle: 110
Duration: Intake 268 Exhaust 268
Valve Lift: .454
melling oil pump m-55hv
Cloyes Gear C-3023X Double Roller Chain
heads
casting # 3927186
metal viton seals
3/8 rocker stud
New stuff
Cam
Comp Cam
Part #: 12-210-2
Grind #: 268H
Valve Lift: .454
#26
What color is that? School bus or Big bird! JFC I used to think you were cool.....
Seriously, it looks like your making progress. Its a very rewarding experience. Just make DAMN sure up cover up EVERY hole, open port and opening when its all assembled.....little nuts find their way into distributor holes way to easily....
dont ask.
dont ask.
#27
daytona yellow. it is a great yellow in person. yep i already dont keep anything little around my block and heads because i dont want any chance of breaking anything.
i got a few things to buy still but i think that i will be able to start putting something together this weekend.
#28
#29
Update !!!!!!!!
I dont have pictures for all i have done as it was 9:30 when i finished and dark so the rest of the pics will come tomorrow.
got the crank installed. i plastigauged to double check what the machine shop did. it all looked good.
installed rings on the pistons. very easy yet frustrating at the same time.
got all 8 pistons installed just need to torque them all down tomorrow.
#30
Update !!!!!
pistons installed
And pistons removed. 3 pistons had bent a oil ring. I removed all of the pistons because turning the crank was very difficult.
then the pistons installed again
timing chain
Lifters
pistons installed
timing chain
Lifters
