350 build up
I've decided to drop a 350 in the 3rd gen I plan to buy.
What would be a good carb, intake, head, cam, compression combo? I'm looking for a quick, torquie street motor. So a powerband from 2000 to 5500. Please include brands, models, specs (duration/ lift), and price is not much of an issue. |
RE: 350 build up
I did some research and this is what I came with:
Cam with 210/220 duration, 112 degrees seperation, and .512/.512 lift. Compression ratio 9:1 155cc volume Heads Holley 750 dp |
RE: 350 build up
looks good,great performance parts, quality, pricey no doubt but if thats not a problem go for it
RE: 350 build up
if you're willing to put a little more work and research into it, afuel injected system could prove more useful. But up to you, and carbed is definitely easier to mantain/understand.
