305 ?s
Old Oct 2, 2011 | 04:21 PM
BigCountry85's Avatar
Default 305 ?s
I got a 305 out of a 83 camaro and was told it was a 350 but I ran the number and its a 305 all i really want to know is whats the difference is because when i looked up a crank on summit they said the crank is for both the 305 and the 350. can anyone help me thanks.
Old Oct 2, 2011 | 04:50 PM
Psycho's Avatar
Are you asking about the similarities of the canks for a 305 vs 350, or the differences of a 305 vs 350?
I would bet Summit knows what crank goes in a 305 and a 350. If they say it's the same then believe it. They aren't A-Zone or Failvance.
From what Iv'e read the flexplate bolts don't line up, so if you replace the flexplate then the starter from the old flexplate might not work either. I assume because of the number of gear teeth.
The new crank should be balanced with the pistons and rods.
Old Oct 2, 2011 | 06:41 PM
torque_is_good's Avatar
are you looking for performance? If so, then go get 45 CID more
Old Oct 2, 2011 | 07:00 PM
im trying to figure out what the difference that makes it a 305 from 350 if the bore and stroke is the same the whats the difference? what makes a 305 a 305 and what makes a 350 a 350
Old Oct 2, 2011 | 07:16 PM
Simple, the bore sizes are different. The 350 has a 4" bore, 305 has a 3.736" bore. Both have a 3.48" stroke.
And no, you can't bore out your 305 block that much to make it a 350.
Old Oct 2, 2011 | 07:21 PM
thanks thats all i needed to know
305 is a lighter and weaker block. It is not a good base to start a build with.
Old Oct 2, 2011 | 07:26 PM
...Or to end with either!
Old Oct 4, 2011 | 07:55 PM
Stevolwevol's Avatar
How is it lighter, or weaker besides being a 2 bolt main?
Old Oct 5, 2011 | 07:06 AM
blackz87's Avatar
Casting dimensions for 305 block internals are thinner then 350. Major reason you cannot bore out a 305 block.
