305 dies after 45 min of driving
Old 02-28-2010, 10:55 AM
I really don't think that temp sensor is the problem. When the engine is cold, the system is in "open loop" mode and the engine runs off of factory computer presets. That temp sensor is what tells the computer to go into "closed loop" mode after the engine warms up, and then the fuel/air mix will be adjusted by the engine management sensors. With the factory FI removed, and an aftermarket carb in it's place, that "open/closed loop" function (to adjust air/fuel mix) no longer exists.
  #22
Old 03-07-2010, 11:14 AM
mybbz28's Avatar
mine did the same thing. then it stop running altogether turns out my fuel pump was bad
5mok3z28
07-22-2012 09:58 PM
akleeve
82-92 V6 Tech
04-01-2010 01:21 PM
Dobbie221
82-92 V8 Tech
09-07-2009 06:26 PM
BONNESBORO
01-02-2007 10:46 PM
97CamaroLT1
04-25-2005 07:14 PM
Quick Reply: 305 dies after 45 min of driving
